2015-05-01
06:16 PM
2023-05-24
08:50 AM
Rubia Torres
2015-05-02 02:27 PM
2015-05-04 04:30 PM
2015-05-05 02:51 PM
2015-05-05 04:35 PM
David wrote:I appreciate you testing that for me. It looks like your walls are doing the same thing I mentioned, based on the material directions across the top of your walls. I assume that if you click on one of the walls, that it would show the right wall coming "through" the left on the corner. Am I correct?
adamsb:
This is what I get when increasing the Junction Order of the weaker wall.
David
2015-05-05 05:13 PM
2015-05-06 02:07 PM
2015-05-06 02:48 PM
adamsb wrote:Based on your screen shot, I thought the issue was the texture on each vertical wall surface (I cannot see the top of the walls in your image). The walls do not miter (there is a legacy switch under Project Preferences > Legacy, but that is a step backwards in other ways). So I am not clear what you are trying to accomplish. You could use Morphs on top of the wall to control the texture appearance if that is the issue.David wrote:I appreciate you testing that for me. It looks like your walls are doing the same thing I mentioned, based on the material directions across the top of your walls. I assume that if you click on one of the walls, that it would show the right wall coming "through" the left on the corner. Am I correct?
adamsb:
David
Do you (or does anyone) know how to get this to be truly mitered? Thanks!
2015-05-06 04:37 PM
2015-05-06 11:03 PM
