wall story settings - V. 17
I am doing a kind of split level plan and every time I try to lower the plate of the lower level it appears on the lower story and no longer on the original story.
I want the wall with a sill plate that is -1'0" from the home story to still stay on the home story and I can't figure out the setting. This seemed automatic in older versions.
thanks.
Eduardo Rolon
Please read,
http://archicad-talk.graphisoft.com/viewtopic.php?t=42871&start=0
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Eduardo, thanks for the link. The summary I get from this is "get the hot fix"?
Eduardo Rolon
Actually is wait for the Hotfix, in the meanwhile you need to use Relink to Home Story.
AC27 US/INT -> AC08
another Moderator
