wall vs mesh
hello there
is this a common problem or just me??
look at the attached file
thanks
8 REPLIES 8
WENDY_NEVERLAND wrote:
hello there
thanks
Does wall disapear in 3D ????? Probably not, so u r making error somewhere
Try using Solid operation with that wall and mesh.
Check layer of that wall, maybe its off in that section
Move section a littlebit !!!!
I never had any problem like that !!!!!! Its your error, i can bet on that !
ok man chill!
if you see more carefully you ll see that half of the wall is visible and only the part that the mesh 'touches' it disappears. anyway i keep moving the section lines but nothing happens.
thanks anyway
ok man chill!
thanks anyway
Plz can u archive that project and mail to me at necko77@gmail.com
Just to see that with my eyes, your pic is 2 small, plz
Im ice cold, no hard feeling,
Stephen Dolbee
Is the fill the same for wall and mesh?
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
hello there
thanks
Ok, i found why is that ! and its cos of u hehehe
Select wall and go to Floor plan and selection /even if u cant see wall in your section, he is there/
then adjast cut fill pen and u will see your wall.
It is very imortant for u to create one wall with corect pens and line weights, line colors and allways use that.
U cant see your wall in section cos you have selected empty fill, then u selected white lines etc. Put everything in black, just see what is your error and then adjust everything like it supose to be !!!
I will sent u one of my walls just to now how i do that !
But that will be tomorow or late today
SEE YA MAN !!!!!
i use empty fill for both.
you think thats why?? i have different section pens though!
ill try that
Two objects that touch and have the same fill "clean up" to each other. That is a basic principle of Archicad. Change one of your fills to "air space" or even "solid fill", white, and the two will separate.
YEAH THATS IT!!!
I used it in sections for the slabs and stairs and i couldnt understand why it was happening for walls and meshed. you re right.!! thanks a lot guys! 🙂
