walls, doors, disappearing...???!!!!
Hi
i am using Archicad 18 and i face a unique problem, sometimes, when i activate the view maps, the walls, doors, etc....disappear in the floor plan (in the project map). but see it all in the view (3D). I have checked the layer settings but with no result.
I then, need to close the project and reopen it to get the original floor plan i did. What could be the reason ?????
4 Replies 4
David Maudlin
Raghunanda:
This could be caused by the Renovation Status assigned to the missing elements and the Renovation Filter currently activated (Renovation Filter is part of a View, but not the Project Map). In the Help files see: Views of the Virtual Building > Renovation > Renovation Filters > About Renovation Filters.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
Raghunanda:
Thank you David, Appreciate your support. Shall revert on the method you suggested me to follow.
I had a similar problem, because I used 2 walls in the same storrey one above each other
1wall) 0-1m
2wall) 1-3m
the window was in 2nd wall; But the first wall would be displayed in the final plan.
so send to back, or cutting plane did the trick
There is a thread which lists a number of reason an element may not be visible. Hope that helps:
http://archicad-talk.graphisoft.com/viewtopic.php?p=235941#235941
