Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
walls intersecting issue
Hello. I am trying to intersect a normal wall with a custom-shaped one and I can't. What is the problem? Thank you.
11 REPLIES 11
Thank you for your help. Yes, that was indeed a polygon wall. I adjusted the nodes, I made them both belong to the same layer and it finally worked.
Glad that was the solution.
Same layer or not will make no difference.
With a polygon wall you have to manually adjust the nodes to get the shape you want.
I would try to avoid using them unless you really have to.
