walls not healing properly
if you look at the attached screendump, my single skin blockwork wall (on the right) is not cleaning up with the 3 x cavity walls on the left.
all walls are set to 0, 2100 height, and all are on wall priority 2.
the problem is that on section and elevation it is showing that corner as a solid line...
any idea's why it is doing this?
the reference line on all 3 cavity walls is on the outside, and the reference line of the single block wall is at the top side as you look at the screen.
12 REPLIES 12
i just realised i had left the skin priority on the single wall at 4, so it was easily resolved.
it'll take me 10 minutes to find the display options thing, i still havent got used to its location since they moved it (for no reason) after V9
percybigun wrote:
....(for no reason) after V9
Belive me - there was a reason 😉 Now the menu layout is more logical.
(You can arrange the menu layout as You wish, though)
Best Regards,
Piotr
Thomas Holm
I prefer the OnScreenMenuOptions toolbar.
