‎2009-07-14 12:41 PM
‎2009-07-14 01:42 PM
percybigun wrote:That is your problem.
...the reference line on all 3 cavity walls is on the outside, and the reference line of the single block wall is at the top side as you look at the screen.
‎2009-07-14 01:59 PM
‎2009-07-14 02:01 PM
‎2009-07-14 02:23 PM
Piotr wrote:oK i've tried that instead of moving the reference lines and it has worked much better (i changed the wall priority of the non-composite walls to 4, and the composite walls are set to 2), but i still have the problem with T-connections in other places on the plans. the T-connection non-composite walls have their priority set to 2.
Make sure the core componenets have the same priority...but - on such connections as Yours - the non_composite wall must be on higher priority by 1 than the same component in the composite wall (on the "T" connections such thing can cause problems so use it only in the cases as You described)
Best Regards,
Piotr
‎2009-07-14 02:29 PM
‎2009-07-14 02:51 PM
‎2009-07-14 03:37 PM
percybigun wrote:I can feel your
thanks to those who answered but i fear this model is in a bit of a mess. also the crappy aircon in this office means i cant fully concentrate on this <b>[censored]</b>-up while my whole body and head is being fried grrrr
‎2009-07-14 04:41 PM
‎2009-07-14 04:46 PM
