what is this red area on section line?
aryastark
valarhello,
i copied these elevation lines from main to module. it appears half tone red area on the section tool line.
do you know what is that red area trying to tell?
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
Podolsky
Ace
I think this is source marker highlight. You can show or hide it on plan (but it's not going to print it).
To hide to you can use command View / On Screen View Options / Highlight Source Marker
Also try command View / On Screen View Options / Marker Range
To change colours (i.e. yellowish) go to Options / Work Environment / On Screen Options
1 REPLY 1
Podolsky
Ace
