when opening 3d window i've got error message...
hi, can someone help me please?
working in archicad 10 and didn't have problems till yesterday.
when i open 3d window appears message: "disk is full(error code-1111), can't extand 3d temporary files."
i check space on my disk and on one i have 19,5 gb and the other 33gb free.
than, why i can't open 3d window?
thank you, all of you!
Does this happen with all files you try to open in ArchiCAD, just some files, or only one? How complex is the 3D model? It seems unlikely to fill up 19GB but I imagine it is possible. Temp file storage may not be reflected in the file system info.
The 3D model is built from the building database and stored (temporarily) in a folder defined by your preferences. I forget the default location, but this means that additional hard drives are of no consequence unless you change the location of this folder.
well, last project was more complacated and bigger than this one, and wasn't any problems - for opening 3d window i need to wait about 40 minutes. with this project,3 days ago, i could open 3d window for 4 minutes.
i just don't understand why now, because 3 days ago, evething was ok, and the project isn't bigger now than then.
thank you a lot for your help!
