why shells do not appear in archicad 14 even as a roof?
i wonder why shells only shows in archicad 15 when saving to archicad 14 you will not able why not even mahe it showed as a roof or object at least without have ability to make modification but shown in archicad14
4 Replies 4
ArchiCAD has never converted any elements created by new tools in one version to objects when back-saving to the prior version, as far as I know. (?) Seems like a reasonable request.
I'm not sure that a user 'save-as' object will work if saved as editable GDL text either since the GDL may very well contain commands that are not recognized in the earlier version either.
I imagine (but have not tried) that user-saving your 15 Shells as one or more binary GDL objects would save just primitives and might display properly in 14?
Karl
David Maudlin
I gave this a quick test with a Shell and got the error message "Can't find macro EXTRUDEDSHELL..." in 14, so Karl is correct.
I don't think 14 recognizes any binary code from 15, based on a quick test.
I think the best approach for teams using various versions of ArchiCAD is for all to use the earliest version for feature compatibility. I don't see the rational for Graphisoft to spend resources on backwards compatibility, I'd rather they use the programmers' time to move the software forward.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Fra
Save as "IFC" and open in ArchiCAD 14?
Can be a solution?
Francesco
AC25 AC26 (Ita)
Mac Studio M1 Max 64 GB - OSX 12.4
David Maudlin
Probably not going to be happy with the results.
David
