why some lines are being lost in cross section window
Hi, I have this problem with cross sections.
Lines that should be visible re somehow lost and I haven't find any way to get them visible.
This happens on some elements that are operators and target elements of solid operations. If I have a roof ans slab that goes threw lower vertical edge of this roof, and I preform operation substraction with downwards extrusion on roof using this slab, I got shape which I want. Roof edge is cut in the way that it has 90 degrees angle, vertical and horizontal parts, like end of rafters or trusses.
Now when I make cross section threw this roof and slab I do not get this line which should by where slab and roof have common edge. If slab is off this line is there, but I need slab and the roof on section.
Any thoughts?
Cris
0 Replies 0
