window ID in elevation view.
Hi
I wonder IF there is a way to be able to se the window ID in elevation view.
Every time the office do a project we have to spend time texting in the correct ID in all the elevations.
David Maudlin
nori0003:
You can use the Label Tool in Elevation to label the window and show its ID.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
...to clarify: David is talking about using the Label Tool as an associative label... it picks up the ID of the window/door "live". This label in elevation is independent of an associative label in plan, etc. (The label tool can be used as an independent/text label too... which would be the same as what you're doing now, nori0003.)
