window display in plan?
How do I make the windows or doors show up in plan?
They're placed, because when I go to the elevation view, they're there, but when I go to the plan, they're invisible.
- still a beginner.
2 REPLIES 2
There can be several factors that effect window display.
  • Model View Options - window / door openings can be shown as openings only (i.e. doors, windows turned off)
    Floor Plan Cut Plane - determines the height at which the floor is deemed to be cut, windows above this may not show depending on whether...
    Walls that they are in are Symbolic cut, Projected, Projected with Overhead, etc.
Check these variables, or post more detailed info for us to help.
Cheers
got it. I believe my story information was wrong. I adjusted and the doors and windows showed up.
thanks.
