window in rotated wall?
Hello.
I am trying to cut a window in a wall that has a special shape: rounded on the inside and polygonal on the inside. Initially I drew this wall as a slab (the right side of the image), but afterwards realized that I cannot cut a window in a slab. So I tried to create the wall using complex profiles, so that I can later rotate it and cut the window in it.
Does anybody know how I could rotate it without turning it into a morph?
Thank you.
igreere wrote:
Hello.
Hello,
Have you tried using the polygonal geometry method for creating the wall?
(see attached image)
Thank you very much. Problem solved!
