2006-06-26
05:18 PM
2023-05-25
05:59 PM
Rubia Torres
2006-06-26 05:23 PM
2006-06-26 05:35 PM
Mike wrote:thanks, Is there a way to just join the two walls together?
Only use one wall that extends from the first floor and into the second floor. In your case make the first floor wall taller and delete the wall on the second floor. You now need to control the visibility of that wall using cut planes versus a symbolic view. Look in the wall setting to find these controls. You also might need to play with your cut plane height...
2006-06-27 03:33 AM
2006-07-08 01:31 PM
2006-07-09 04:21 PM
2006-07-09 11:29 PM
You can also create an empty opening on the second floor.That's the worst advice I've heard for a long time!
