2011-09-26
09:01 PM
2023-05-26
02:30 PM
Rubia Torres
2011-09-27 10:13 AM
cremsberg wrote:Try opening your window's settings, then go to its parameters; in the
Is there a setting to get AC14 window sill and stool to display on the floor plans, as well as casings?
2011-09-27 04:00 PM
Try opening your window's settings, then go to its parameters; in theThanks, Adrian, but I can't find that this works. Oddly, things look as I want in the settings window preview, but not on my actual plan. I have tried with and w/o composite walls. I've tried 2D Representation at Detailed and at Scale Sensitive, but neither shows the sills the way I want.Optionsor 2D Representationcategory (I am thinking there are some differences between the US and INT libraries) try searching for a parameter called 2D Detail Level. Change it to a more detailed scale.
2011-09-27 04:30 PM
