window transparency in elevations
would you please let me know how to switch off window transparency in elevations. Thank you in advance
3 Replies 3
Thomas Holm
IN AC10 you have to turn it off in the 3D window settings, if I remember correctly. In AC11 it's in the sections settings dialog
Yes, in AC10 in window settings, but there are things that could make your head bang. This setting are saved in the viewset so if you have saved an viewset for sections when transparence is on, then it will be on when you click on that viewset.
And it's buggy so watch your drawings.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
