Losing stair in section window
Anyone have a solution. We are losing stair in the section windows. We did find that when we change story some stair dissapear on the other one appear.
On windows xp we don't have this problem on mac intel
Stephen Dolbee
This has happened to me, as well. If you move the section marker slightly, the stair will appear again. That's worked for me, anyway.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
I had this happen with stairs (disappearing) and composite floors / complex profiles (turning in one fill type). Indeed moving the section marker as described did the job, although it was a temporary solution because from time to time, not knowing the reason, the same problem occured.
To be honest, I only had this problem in AC10, using AC11 for 6 months now I did not see it happen again
