Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
2012-07-1210:28 PM - last edited on 2023-05-2412:55 PM by Rubia Torres
my plate are slabs, walls go all the way around and at the stairwell portion the plate is opened up. I have windows that are mid plate and not punching through the walls on two floors. without making one wall here, is there a way to make the window punch through all walls its set in?
