windows reveral problem
Hello
i am having problems with windows reveal. I set that insulation is 5 cm in the frame but nothing happens. Doors works fine. In section windows also works fine only in floor plan nothing happens.
vistasp
Have you checked your "2D Detail Level" and "Show Reveal on Symbol" settings as in the attached image? The same window seems fine in AC13 at least.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
vistasp: i am a little embarresed. i checked everywhere and i did not see this feature. Thanks it works perfectley!
vistasp
We all miss the seemingly obvious once in a while.
= v i s t a s p =
bT Square Peg
