windows reveral problem
Hello
i am having problems with windows reveal. I set that insulation is 5 cm in the frame but nothing happens. Doors works fine. In section windows also works fine only in floor plan nothing happens.
3 REPLIES 3
vistasp
Have you checked your "2D Detail Level" and "Show Reveal on Symbol" settings as in the attached image? The same window seems fine in AC13 at least.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
vistasp: i am a little embarresed. i checked everywhere and i did not see this feature. Thanks it works perfectley!
vistasp
We all miss the seemingly obvious once in a while.
= v i s t a s p =
bT Square Peg
