2007-11-1611:53 AM - last edited on 2023-05-2305:04 PM by Rubia Torres
2007-11-1611:53 AM
howdy
having some issues with tracker in v11
here is what i have done in v9
- draw a line
- place the user origin at the end of the line
- select another object on the drawing
- type in (say) x 200, y 200 and the object moves to 200,200 from the user origin
i can also do this in v11 if i have tracker switched off
if i have tracker switched on.... when i enter x 200, y 200 the object only moves relative to its starting point... not to the user origin
I think you need to check the absolute/relative button in your Coordinates Palette, it should be up, without the deltas showing, to get the behavior you describe.
You should also check your Tracker settings (Work Environment > User Preference Schemes > Tracker and Coordinate Input > Coordinate input logic) there is a check box for "Show X-Y Coordinates relative to User origin in Tracker".
HTH
David
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
a drastic fix for a small issue..... but none of the settings that should have worked seemed to
is it just me..... or does it feel like we have made a small step forward and a few steps back with v11... not only in functionality/usability but also in stability
