zoom problem: it zooms another point
Help!
While opening floor plans, it is always zooming another empty place. It is really hard to control relation between plans
3 Replies 3
I have moved this post to the "Working in Archicad" section of the forum.
I am assuming you are using views in the View Map to open your plans.
Have a look at your view settings.
They were probably created with the zooming option set to "Zoomed Area".
Change this to fit to page or open your plan and zoom to the area you do want it to open at and change it to "Current Zoom".
Thank you, what you assumed is true.
Patrick Stimpson
This worked for me !!! Archicad 25
Thanks you!!!
