Our Community
Ask questions about this community and the platform.
Cross contamination of languages
Post from language specific forums are shown by the unread discussion function for the international forum. This has been the case since the first language but is becoming an increasingly annoying issue as more languages are added. As noted here - even after the last restructure it lacks an easy and efficient way to keep track of forum activity a part from a bookmarked paged.... So either set up a proper forum or at least keep the languages fully separated.
6 REPLIES 6
mthd
True we don’t want important wishes getting lost in different forums.
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
Certificate IV Architectural & Building
Technology, (Estimation & Administration).
I use an unread post link all of the time.
The only time I see it list other language posts is when I have read all of the unread messages and I try to use it.
Sometimes I will see a blank page, other times I will see a list of all language posts - I am not sure why.
Clicking on the main Graphisoft Community link and then using the unread post link will re-set it to just the INT unread posts.
Claudius
Hi @thesleepofreason
Sorry to hear that you see posts in unrelated languages in your unread posts page. Just to help me understand how you end up with those: Do you happen to open the unread discussion page straight from a browser bookmark/favorite by any chance? We've heard reports that in that case the user session scope might be lacking the language category and thus lists posts across all languages. Would help if you could confirm that's the case so we can narrow down the issue.
Claudius Henrichs
German Community Manager
Leipzig, Germany
Hi Claudius,
Yes - I´m opening the page from a bookmark in chrome as there isn´t any other way to reach it apart from digging up the old post about it (?). In my opinion this should be put front and center, replacing hot topics on the landing page.
You seem to be on the right track as breadcrumb only says Unread Discussions and not Graphisoft Community (INT) > Unread Discussions and investigating it - it occurs when using the link without having opened any other community page during the browser session.
Thanks for confirming my suspicion. We'll need some further investigation together with our platform provider, but I'm confident we can come up with a solution to show only unread content from the international community.
Meanwhile as a workaround it should help if you just load any page within the international category, even just the front page before opening the unread post page.
Claudius Henrichs
Leipzig, Germany
Yes, it would be perfect to have an "Unread" button here.
Seems to be the only one missing.
