a month ago
Why can I edit my own post but can't edit a reply in someone else's post?
Greetings
Solved! Go to Solution.
a month ago - last edited a month ago
When I track down the post from the screen shot, in what you have posted,
it tells me the it is locked,
and I assume the entire thread is locked as the thread has this at the bottom of it and all the "Post reply" are greyed out.
I don't know if this helps.
a month ago
Maybe the post you're trying to edit your reply to has been locked?
a month ago
You are simply not permitted to edit anyone else's post.
Otherwise we would be in all sorts of trouble.
Imagine if people started editing your posts because they didn't agree with what you said.
You can only edit what you post yourself.
a month ago
I think the question actually was: why can't I edit my own reply in someone else's post, not other peoples posts.
a month ago
Yes that's right, why can't I edit my own reply in someone else's post, not other peoples posts?
a month ago
Now I re-read the post, that would seem to be what it is asking.
Anyone should be able to edit a reply so long as it is their own and the post has not been locked.
Just click on the 3 dots to the right of the reply.
I can't test it though, because as moderator, I can edit anyone's post.
a month ago
Do you see this?
Yes, but the option 'Edit reply' is not available when you want to edit the reply in someone elses post.
a month ago
I'll bring this to @Noemi Balogh 's attention.
Noemi, have you any ideas why Dontknow can't edit there own replies?
