Dontknow
Edit post
Why can I edit my own post but can't edit a reply in someone else's post?
Greetings
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
1 Solution
AllanP
When I track down the post from the screen shot, in what you have posted,
it tells me the it is locked,
and I assume  the entire thread is locked as the thread has this at the bottom of it and all the "Post reply" are greyed out.
I don't know if this helps.
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
Go to post
13 Replies 13
CosminF
Maybe the post you're trying to edit your reply to has been locked?
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
You are simply not permitted to edit anyone else's post.
Otherwise we would be in all sorts of trouble.
Imagine if people started editing your posts because they didn't agree with what you said.
You can only edit what you post yourself.
CosminF
I think the question actually was: why can't I edit my own reply in someone else's post, not other peoples posts.
Dontknow
Yes that's right, why can't I edit my own reply in someone else's post, not other peoples posts?
ArchiCAD 25.
Now I re-read the post, that would seem to be what it is asking.
Anyone should be able to edit a reply so long as it is their own and the post has not been locked.
Just click on the 3 dots to the right of the reply.
I can't test it though, because as moderator, I can edit anyone's post.
Do you see this?
Dontknow
Yes, but the option 'Edit reply' is not available  when you want to edit the reply in someone elses post.
ArchiCAD 25.
I'll bring this to @Noemi Balogh 's attention.
Noemi, have you any ideas why Dontknow can't edit there own replies?
AllanP
