2023-06-01
11:24 PM
2023-06-02
08:07 AM
Noemi Balogh
Not sure if this is the correct place to post this query/observation.
When ever I make a post, I want/have to add a label (great way to search later).
The only issue, is that you have to pick from one that already exists, but the options don't seem complete.
When you attempt to add one, you get a notification, "Correct the highlighted errors and try again.".
For example, below I posted a "Wish" regarding columns, "Columns" wasn't an available label, nor was "3D...".
Yet Beams and Objects are available.
Solved! Go to Solution.
2023-06-21
09:09 PM
2023-06-26
04:51 PM
Hi @Karl Ottenstein & @Noemi Balogh
I wonder if the Archicad "Order of Development" list might be a useful source for some additional Labels.
source: https://twitter.com/ARCHICAD/status/1324017146641453056/photo/1
2023-06-26 08:11 AM
Josh,
I have removed the image from your post because that image is part of the BIM Manager Program and so its contents are for participants of the program only, just as any other material on these paid courses.
But just to make sure, did you find this image posted somewhere on a Graphisoft website? In that case, I will consider putting it back.
2023-06-26 08:23 AM
Hi @Laszlo Nagy
No problem at all, FYI even thou I do have the same image saved, having done the course, I actually did a google search to acquire the one I had posted.
I was unsure if it was sensitive/restricted.
I think this was the link (google search) - please feel free to delete this post.
https://www.google.com/search?newwindow=1&rlz=1C1ONGR_enNZ1029NZ1029&sxsrf=APwXEddPNUzBFdZp3bWyLkp68...
It appears to be from a Twitter post, even thou I don't have a Twitter account, I was still able to right click and save image.
2023-06-26 04:52 PM
Thanks John, that is fine as it was posted on the official Archicad Twitter account.
I have put the original image back, along with a link to the source.
