I created an object that simulates in which direction a rainbow can be seen when the conditions are met.
The direction of the rainbow changes as the sun's azimuth and altitude change.
View Cone
Sub Rainbow
Camera following
Really cool & fun idea!
Thanks😎
Thanks to @Kotetsu, this object is now available for download on BIMcomponents. Click here to try it out.
At the end of the Parametric Factory stories, you can find a list of objects from the Community challenge to download as well.
Cheers!
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
