AC 21 GH LIVE CONNECTION 4022 CRASHES GRASSHOPPER & RHINO
Rhino instantly crashes to desktop whenever i try to open grasshopper after live connection 21 installation is done.
I've experienced the same problem with latest version of AC20 GHLC
-John
2 Replies 2
Has anyone run into the some problem? or maybe even find the cause of the problem and the solution for it?
Is it a bug on the archicad or on the Rhino/Grasshopper side?
Any help/answer is greatly appreciated
Best regards,
-John
Nevermind, i've solved the problem, turns out there's a conflict with TT_Toolbox component that i've installed earlier.
if there's anyone out there who also experiencing similar problem, try to exclude (delete or move) other grasshopper plugins from grasshopper library folder
Cheers
-John
