‎2019-11-30
12:27 AM
‎2023-05-11
11:05 AM
Noemi Balogh
‎2019-12-01 02:56 PM
‎2019-12-01 10:56 PM
‎2019-12-02 08:48 AM
‎2019-12-02 11:28 AM
leceta wrote:
if with "edit existing instances parameters" you mean to edit the paremeters of objects already placed in the document, then NO its not possible.
Laszlo Nagy, the chapter your refer is about accesing parameter of objects existing in the archicad library, but not those instances created on the document. Or am I missing something (big)?
Current state of grasshopper connection only can Read archicad database, even Create (some) elements on the database, but you cannot Update existing elements, nor Delete them. Just Read and Create. Not Update and Delete. This is an important feature that plugins has not implemented yet, if ever, known that GDL capabilities, after years of development, has not implemented neither. Again, Am I missing something or this is just a feature limitation by design?
‎2019-12-02 04:01 PM
You guys should make a wish for this. If you do, please post its link in this thread.Done:
