Parametric design
About Rhino & Grasshopper and PARAM-O.
ERROR IN AC22: GRASSHOPPER-ARCHICAD LIVE CONNECTION
I am having an issue with installing the updated Grasshopper Live Connection in ArchiCAD 22. I get the error that it is detecting it is already installed. I tried the terminal command listed in the article below for this same issue with AC21, but it did not work. Can you please assist? Thank you!
https://helpcenter.graphisoft.com/knowledgebase/75721/
1 REPLY 1
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Well, we would need to know a little bit more than this to be able to help:
  • Based on that you mention the terminal thing, I suppose you are no macOS. Which version are you using? (10.14, 10.13, etc.)
  • What version of ARCHICAD are you using and what version of GH-AC connection are you trying to install? (e.g. AC22 build 5009 and GH-AC build 4027.0)
  • Do you have any other version of ARCHICAD installed?
  • Have you had any previous version of GH-AC connection installed? which version?
  • Are you sure you completely removed it? It has parts in the ARCHICAD Add-on folder and in the Grasshopper Plugin folder. Check the Uninstall section of this guide for help with this.
Regards, Daniel
PS. With technical difficulties it is a better option to contact your local support team. They are faster to respond and have more insight.
Daniel Alexander Kovacs
GRAPHISOFT
