2021-05-24
07:30 AM
2023-05-11
11:02 AM
Noemi Balogh
2021-05-24 08:06 AM
2021-05-24 03:04 PM
Barry wrote:With Shell I could not produce a continuous elliptical curved profile surface (as one gets with a circular arc profile) —magic wand segments make a mess of it all, especially at the junctions of vaults with different profiles. And I could not produce Shell edge faces normal to surface —I could only get them normal to contour plane, and parallel to opening axis. I may be missing stuff, I have never used Shells much.
is there any reason why you did not add thickness to the shell in Archicad in the first place?
You can still SEO the holes in a thick shell or you can just use the 'Create Hole in Shell' command (select shell and right click) and draw the hole.
2021-06-02 11:28 AM
2021-06-03 07:12 AM
Szamimate wrote:The original problems were
1. ArchiCAD
In ArchiCAD I got this with the shell tool using the magic wand to create the shell, then modifying the boundary of the shell. ArchiCAD uses meshes to approximate curved surfaced in the 3d window, so the junctions are a bit messy if you really zoom in. Is that the problem?
2021-06-03 11:05 AM
2021-06-04 02:40 AM
Braza wrote:Thanks for pointing at XFORM anyway. I had never noticed it, if I ever saw it I must have thought it was something I would never need.
With the XFORM command you can model the opening as if it would be plan and distort it with the command.
p.s.: Ok. Never mind. I see you want the sloping part of the opening to be arched.![]()
2021-06-04 11:11 AM
