2026-04-15 01:26 PM
FloorForge - prototype of an apartment layout generator add-on for ArchiCAD 29
I've been working on a native ArchiCAD add-on that automatically generates apartment floor plan layouts directly in the model. Sharing it here to get feedback from people who actually use ArchiCAD in residential practice.
What it does (current prototype):
Current limitations I'm aware of:
The generation algorithm still needs optimization - the solver logic works in principle but room placement isn't always satisfying, especially in irregular outlines. Some variants are better than others and I haven't yet nailed the rules for what makes a layout genuinely good vs. technically valid. This is the area I'm actively working on.
Planned next:
- facade recognition (rooms requiring windows placed at exterior walls)
- template library based on real Polish residential projects
- stretch engine for adapting reference layouts to new outlines
- automatic floor division - define the apartment mix (e.g. 2×studio + 1×2-bed + 1×3-bed), add-on divides the floor plate and generates the complete layout
Why I'm posting:
I'm curious whether this kind of tool would actually be useful in your workflow, and if so - what would need to work better before you'd reach for it. Honest reactions welcome, including "this isn't a problem I have."
Happy to answer questions or show more of how it works.
2026-04-16 12:14 PM
Looking neat! would be great to be able to test to be able to see more. Anyhow as i said, looking great!
2026-04-16 01:27 PM - edited 2026-04-16 01:27 PM
Thinking about something near Your idea - in plain GDL for some time - just work in progress:
GDL cant make new walls like Your addon , so my idea is just a tool for room-configurations - to think about it..
german, but just play forward.. (/Work in progress - has some flaws..)
AC29EduAut:
a month ago
This tool is incredible; it has the potential to save a lot of time and allow architects/designers to explore more ideas in the creative process. It would be very useful for my case. And I don't know if this applies here, but the other day I was thinking, I do a lot of surveying, which I sometimes have to do manually. That is, I draw the room layout on paper by hand, and what if it were possible to import this drawing as, for example, a PDF or image, and the plugin could "read" the layout of the drawing and the duly noted measurements, and then automatically insert the walls, leaving only the work of adjusting minor inconsistencies? I consider this to be something that would add a lot of value.
