Parametric design
About Rhino & Grasshopper and PARAM-O.
Free form design process
Ahmed_K
Mentor
Hi guys, i just installed rhino and archicad to grasshopper connection, for some testing purposes,
so i wan to create a simple nurbs free form surface in rhino and see the surface updating in archicad ( without using grashopper, just a rhino surface )
is that possible ?? any guidelines or advices to start ?
thanks !
Archicad 27
Windows 11 professional
Eduardo Rolon
AFAIK in order for it to update continuously you will need to link it using GH. If not then you will import them as objects.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
furtonb
You can hotlink Rhino files as you would with .pln or .mod files. Once linked, you can change the Rhino model and have it updated after refreshing the hotlink.
odv.hu | actively using: AC26-28 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
