2025-06-27 08:53 AM
So, I get disappointed by these yearly new features releases from Graphisoft, because hardly anything gets done to the big white elephant hiding in the china shop - GDL... I mean, having AI-assistant is nice, but that's like adding curtains to a house that needs foundation work. Is there any chance we will ever see an update to the GDL? Param-O is just a wrapper, I'm thinking something closer to RhinoScript - something from this century.
2025-08-25 12:04 PM
Totally agree, GDL is already an outdated language, but it seems Graphisoft will likely continue to use it for many years to come. I don’t expect much anymore—the best thing they’ve done in recent years is redesign the interface and add syntax highlighting. They’re just not moving forward as fast as Rhino.
If possible, GDL should have geometry capabilities as powerful as Grasshopper scripting, and it should allow the use of Python when needed. In other words, users should be able to choose between visual programming or coding depending on their needs. The IDE and debugging tools must also be much more modern.
2025-08-26 10:26 AM
"redesign" being a slow and buggy overlay which is not worth using if you do any decent amount of GDL scripting... That was the case when it first came out, have not tried since... I still do everything in AC22...
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2025-09-15 07:16 PM
@Dmitriy_Averyanov Rhinoscript is Rhino's GDL. It's like GDL, a language that is bounded to the program that implements it.
I on another side, would like to see 3 things implemented in Archicad's GDL:
2025-09-16 06:04 AM
My dream feature to add to GDL is an improved hotspot. One that would allow you to utilise many of the pet palette functions from other tools. Things like elevate, arcs, add /remove polyline nodes etc. I live in hope…
Real debugging tools would be great too @Nader Belal ☺️
2026-03-14 08:13 PM
It's a big handicap for many users,
In the last 2 weeks, i wasted hours on searching how to create a simple concrete li tel for a window with gdl, once you find a solution you must code, debug, understand where the code fails, test, stress, and ofcourse, abandon the process, i wasted eniugh time on a very simple thi g that should be done inside a mature bim software,
Maybe when i get some time to wate in the future i'll try.
This handicap is no more acceptable....
