Parametric design
About Rhino & Grasshopper and PARAM-O.
GH-AC Live Connection 1.7 cannot run in ARCHICAD 20 6005.
GH-AC Live Connection 1.7 (20.0.5034) cannot run in ARCHICAD 20 6005. (TAI)
5 REPLIES 5
Aaron Bourgoin
It doesn't run for me either - on the Mac version. This is annoying because I couldn't even launch AC5025USA. I did a clean install which worked, patched to 5025 and the crash on launch came back. Decided to patch to 6005. ArchiCAD started. On installing 6005, the Add-On Manager reports that the Grasshopper Connection is outdated.
Has anyone been able to get this to work? If so, how did you do it.
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
the same here on windows 10.
In the add on manager of Archicad it is written that the plug in is outdated...
Please fix it .
regards
Postby anna » Tue May 23, 2017 9:33 pm
thank you for reporting this! The ARCHICAD 20 Build 6005 will require the update of the Grasshopper connection too. (If you now check the Plug-In in the Add-On Manager, it will state that the file is outdated and the Add-On cannot be used with this ARCHICAD version.) The Build 6005 can currently be reached only as a Preview because we are still testing it before releasing it as an official Update. The newer Grasshopper Plug-In, which is required by this Build will be released on our site together with the official Update.
Sorry for your inconveniences and thank you for the patience!
Aaron Bourgoin
Graphisoft quietly released a version of the Connection tool compatible with AC20 build 6005. Not sure why they don't announce these on their beta forum, but it's now available.
Rhino 8 Mac
MacOS 15.2
Link to announcement post and download link:
http://archicad-talk.graphisoft.com/viewtopic.php?p=268201#268201
