Parametric design
About Rhino & Grasshopper and PARAM-O.
Grasshopper-Archicad 28 Live Connection can't find Rhino 7 on install (Rhino 8 support, btw?)
Martin Jan Rosa
Hello, I am struggling with installation of the Grasshopper-ArchiCAD 28 Live Connection. I have Rhino 7 installed, but I am getting an error message that "Rhino is not found on this computer".
GC from ArchiCAD 27 is already uninstalled. No other version of GC is present on my machine.
Additionally – will there be a GC for Rhino 8? I still see GC for Archicad 28 still supports just Rhino 6 and 7.
(I've tried it with Rhino 8, getting the same error message. Now, only Rhino 7 is installed on my computer, so there should not be any confusion between two versions of Rhino).
Archicad 28 CZ, MacOS 15.0, M3 Max MacBook Pro
Martin Jan Rosa
Freelance Architect and BIM consultant
martinrosa.cz | Linkedin
GRAPHISOFT Certified Archicad BIM Manager, 2021, 2023 | Archicad 29 CZE | macOS 26 | MacBook Pro M3 Max
Martin Jan Rosa
Problem solved. A computer restart and launching and closing Rhino and Grasshopper helped. The installation then runs and the connection can be established.
Moreover, it works with Rhino 8 as well. Therefore, I'm leaving this post here for information, because the GC download page still only lists Rhino versions 6 and 7 for GC with AC28.
Martin Jan Rosa
Martin Jan Rosa
Martin Jan Rosa
Bart-Jan
So, do I need Rhino 7/8 for this? I have AC28 and Rhino 6, so I hope it will work with that. But so far i only see a link for rhino 7/8.
Anybody has any clue?
Thanks!
Setup info provided by author
