Parametric design
About Rhino & Grasshopper and PARAM-O.
SOLVED!
Grasshopper-Archicad Connection 2.0 BUG REPORT
When ever i modify the place or shape of morph object in Rhino 5 the result is Rhino crashing.
The same process Rhino 6 is not crashing but in Archicad 3d window all the object are disappearing !!!
Program Versions : ARCHICAD 21 Update 5021
12 REPLIES 12
Carstenem
Just installed everything I need to use Grasshoppers - ARCHICAD life connection.
I got:
- windows 7
- AC 21 ( latest update )
- Rhino 5
- Grasshopper-ARCHICAD_Connection-21-INT-5011-1.0
Next steps:
- Opened AC
- then Rhino
- then Grasshopper.
So they are all running fine.
- Then opened Grasshopper connection in AC - palette opens.
- Then click start connection
message in palette <Grasshopper not running> ( green circle is spinning ) but there is no connection to Grasshopper
Grasshopper should then add an ARCHICAD palette, which it is not.
Sooooo I am stuck for now and can't test/play with the connection
Anybody has an idea how to resolve this ?
Cheers Carsten
ARCHICAD Speed Modeling
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
Try uninstalling GeometryGym or any other plugins that have Newtonsoft.Json.dll
GeometryGym is at Program Files (x86)/Geometry Gym
Hi Carstenem, give a name and save the grasshopper file even if it is a blank canvas and then try to connect it
