Grasshopper-Archicad Connection 2.0 BUG REPORT
When ever i modify the place or shape of morph object in Rhino 5 the result is Rhino crashing.
The same process Rhino 6 is not crashing but in Archicad 3d window all the object are disappearing !!!
Program Versions : ARCHICAD 21 Update 5021
1 Solution
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello Everyone,
I can confirm that there's such a bug in the latest version of the connection Add-on (5011.0, v2.0) - Rhino crashes when ARCHICAD morph is updated through the Connection add-on. We plan to fix this in the next update, but until then, you can roll back to 4022 (v1.8 ) as that version is unaffected, or you can transfer these elements as Objects instead of Morphs (with the new Object node).
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
Go to post
12 Replies 12
same problem whit morph, and when I change 2d curve in archicad (connected to grashopper) it crash
I use macos system,
program ver: archicad 21 update 5021 grashopper arc con. 2.0
Mac Pro (2017)
3 GHz Intel Xeon W
128 GB 2666 MHz DDR4
Radeon Pro Vega 64 16 GB
It is helpful to other users to share your bug reports here, but as a user forum, there is no guarantee that Graphisoft will see what you share here.
Please report your bugs through the technical support channel for your country.
I attach report, thank you
An OS X crash report is not of use to your fellow users. Please contact your local Graphisoft technical support to report your issue. For Turkey (listed in your profile), you should contact BİMSOFT YAZILIM TEKNOLOJİLERİ ANONİM ŞİRKETİ here:
http://www.graphisoft.com/info/where_to_buy/europe/#TR
Thank u for your interest, I already contact whit them.
I send my grashopper code i attachement , as see in red buble , when I turned on(boolean toggle), rhino crash, ( when I send morph object to archicad)
I found some article in graphisoft web site about morph ( https://helpcenter.graphisoft.com/tips/collaboration/grasshopper-archicad-live-connection-2/grasshop...) but it din't help ,
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello Everyone,
Regards,
GRAPHISOFT
Thank you Daniel !!! , I can sleep tonight ( I just trow the computer from window)
V1.8 work ...
*When new update will came for macos system?
**can u explain " with the new Object node" ??)
Utku
Same to me.AC 5021 objects is disppearing in 3d window when using AC-GH connection 2.0.But if just open nomal file without connection is ok.
BTW rhino is 6
