Parametric design
About Rhino & Grasshopper and PARAM-O.
Grasshopper - Archicad Live Connection | Points query
Josh Verran
I'm not sure if I have the right forum here (or even if this should maybe be posted on the Rhino - Grasshopper forum).
I'm having a bit of trouble with "points", in particular adding nodes that require point data as the input, but getting notifications advising that the data doesn't contain points.
I feel like I haven't worded that well, so perhaps this image will clarify.
There is a node called "Construct Point", which is being used successfully to place columns (anchor point).
Want to use those same points to create a curve/line, but getting notifications that no points are being found.
I'm only just starting on Grasshopper, so still have much learning to do.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
Gino Hansen
Hi Josh,
It looks like something is wrong with your Data Tree. Try to flatten the point output.
AC 16- AC27
WIN 10 , Mac Studio OS 12.6
Josh Verran
Thanks Gino
I'll do a search on what Flatten is, I have seen that on the right click, I don't suppose you could describe what that does?
Hi Josh,
a short Info about this you can find here:
https://www.youtube.com/watch?v=-JRWoTzI9Co
There are also a lot of Tutorials regarding the topic "Data Tree". I'm not an Expert yet, but some knowledge of this  is very important before starting advanced scripting.
AC 16- AC27
