2022-11-17 06:35 PM
I worked until now with AC 24 and the ACGH connection without problems.
Today I tested the new version of the Connection.
I'm working on M1 Max Silicon with this settings:
System macOS Monterey 12.2.1
Archicad 26 4019 INT
Grasshopper Connection 4023 1.1
Rhinoceros 7.25.
I'm working with my new objects created in AC connected with GH, with new parameters for creating panels.
I found these Issues:
I hope, there is someone available to discuss on these issues.
Mario (ArchiRADAR)
2022-11-19
12:06 PM
2022-11-21
02:43 AM
I made a deep test, both on simple objects and columns (AC 26, GH Plugin 4023).
If I compare the speed of generating model comparing AC 26 & GH 4023, with AC 24 & GH 6010, the second one is 10 time or more faster. I will came back to AC24 until I understand the reasons of these behaviors.
Could it depend on the fact AC26 and the new plugin are not suitable for working fine with M1 Silicon and Rosetta?
I hope to test as soon as possible the GH plug in for Silicon.
The image attached is made in AC 24; I can work without problems on a large amount of objects and columns. As you can see, I can modify the objects also with the connection turned on.
2023-01-02 09:40 AM
I made some test in AC26 Silicon 4024 with GH Connection 4024. (last version available)
The issue seam to stay always there.
Archicad send back informations of the geometry to Grasshopper each time I change the MVO.
This happens also if in GH the AC objects component are turned on "Preview off" .
I think this beahaviour is due to have a preview in Rhino-GH of the AC geometry.
On large quantities of elements this "sending back" informations create a huge delay.
In the general use of the Connection the designers doesn't need a preview in Rhino-GH; but a quick regeneration in AC.
I think a solution could be add an extra option in the Rhino-GH Archicad Palette with "no preview", further the already existing options "Detail" and "Simple".
The potentiality of the connection is huge.
I hope to have a these issues solved.
