Parametric design
About Rhino & Grasshopper and PARAM-O.
Grasshopper Installation failure with archicad 22 EDU
Goodmorning everyone!
I am a student that use the student license on Archicad 22. When trying to install the Grasshopper archicad connection an error messagge appears about the impossibility to find Archicad 22 itself ( as you can see in the images attached ).
What should i do ?
Thanks in advance
Edo.
1 REPLY 1
furtonb
Just update your ARCHICAD to the latest version (build 4023).
Go to Help/Check fo updates, download the updater, install it, then try again.
odv.hu | actively using: AC25-27 INT | Rhino6-8 | macOS @ apple silicon / win10 x64
