2020-02-04 05:44 PM - last edited on 2023-05-11 11:04 AM by Noemi Balogh
2020-02-04 06:07 PM
2020-02-04 09:20 PM
2020-02-08 05:26 PM
JGoode wrote:
I'm trying to create a script to pick up my zone geometry and then create a slab using that geometry which I have working, up until I try to create it with a hole in. When the zone / slab has a hole in (e.g for a column) everything crashes when trying to update in AC. Either I'm doing something really wrong and instead of being told by Grasshopper, it's just crashing or there's some sort of bug.
I'm on AC23 and using Rhino 6.
It also does the same thing if you do something really basic such as Slab In > Deconstruct > Slab Out as attached.
Thanks in advance
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-02-10 08:14 AM
Minh Nguyen
GRAPHISOFT
2020-02-10 10:37 AM
2020-02-10 08:19 PM
Steve wrote:Hi Steve,
The download you gave the link for will install a 32bit version of Python. Does that make any difference? ArchiCAD 23 and Rhino 6 SR22 are 64x.
Minh Nguyen
GRAPHISOFT
2020-02-11 03:34 PM
2020-02-11 05:22 PM
JSN wrote:I've been informed that it is in fact a bug that causes crashes when trying to create a slab in ArchiCAD that has a hole in it. There is currently no workaround.
We have recently upgraded the Livebridge from AC22 to 23 and know facing various issues. One of them is exactly as you described it. Rhino crashes when a simple Reshaping Action on a Slab is being performed - most of other scripts which have been running on the Previous Version smoothly tend now to crash more or less randomly - Performance is really an isse now.
