Isadora Almeida
How to move the head of a track on plan? (PARAM-O)
I created this fixture with track and heads with the PARAM-O tool, but I need the heads to be able to also be located manually on plan, does anyone know how to do it?image_2023-01-02_161724738.pngimage_2023-01-02_161108591.png
1 Reply 1
scottjm
Mentor
PARAM-O frustratingly does not allow you to add hotspots.
You can however add a parameter which would allow you to set the distance of each light in the object tool settings.
If you desperately need hotspots in 2D you’d have to modify the param-o object gel and all the hotspots that way.  This however will loose the ability to edit the param-o code in the future.
