Kamelite
Param-O - Lines removal?
My first attempt at Param-O.  It is cubes stacked on top of each other. Is it possible to remove the black lines visible on the image?
They are visible when I use other surfaces to, so telling me to change line color will be apliccable to this view only...
.Kamelite
Windows 10, Archicad 27,28 and 29
2 Replies 2
fede0184
Do you mean something like the one in the first photo?
have you used the union node (the one in the second photo)?
Kamelite
I have not, and it worked like a charm.
Thank you!
.Kamelite
