ryejuan
Parametric or Param-O
I just wanted to post this out here maybe some users can give ideas or tips or techniques to do this much simpler and easier.
The image below is done using a beam which I have manually adjusted the lengths in a section view to make it more random.
My question is there an easy way to do this? like Param-O and how difficult or easy it would be? Thanks for the help in advance!
Operating system used: Windows 10 Pro 22H2
WINDOWS 11 PRO
1 Solution
cuba
You can achieve this in Param-o, but GDL offers more control over the process. Here’s a setup in Param-o where the bars are drawn through, and the seams/joints are cut out. However, a drawback in Param-o is that you don’t have control over the seams positions between adjacent rows.
To make adjustments easier, I've added just additional hotspots in GDL.
Have fun!
Apple M1 Max 32 GB
Latest AC
Go to post
2 Replies 2
cuba
Have fun!
Apple M1 Max 32 GB
Latest AC
ryejuan
@cuba Appreciate your help with this, and thanks for sharing the gsm file. For sure it will help a lot of other users that are looking into this kind of objects. 😎
WINDOWS 11 PRO
