Paramo-O grid - Grid points tool issue
In paramo tool Grid Tool behaves strange way. If Count X or Count Y values are set to "1" nothing is shown in 3D. Only things started to be shown from value "2". In my opinion grid should not show anything if Count X or Count Y is set to "0".
Count X = 1, Count Y=2. Nothing in 3D.                                       Count X = 2, Count Y=1. Nothing in 3D.
AlgimantasKuprenas_0-1695102010461.png  AlgimantasKuprenas_1-1695102065874.png
Count X = 2, Count Y=2. Finally 3D starts to be shown.
Please don't tell that Param-O is expermental tool and because of that it works not like it should be. This expermental tool is already implemented from version 24.
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v29 INT / NOR
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
3 Replies 3
Have a look at the 'distribute existing object' example here ...
https://community.graphisoft.com/t5/Libraries-objects/Create-Custom-Objects-on-Windows-and-macOS-wit...
This lets you multiply in a circle or a grid.
Change the 'GDL object' node to an object you have in your library and attach it to the grid example.
Downloaded example, but that one also showing nothing when I change COUNT to "1" - in this value all elements disapears. Same issue in this one.
cuba
A value of 1,5 on count x & y will show only one object (not very logical...)
Apple M1 Max 32 GB
Latest AC
