Parametric design
About Rhino & Grasshopper and PARAM-O.
RGB Mesh GH Object
brenoveiga
Hello!
I'm trying to use the RGB Mesh GH Object (https://bimcomponents.com/GSM/Details/23681)
to transfer colored mesh geometry from Grasshopper to Archicad. I've followed the workflow created by Dániel Kovács presented in this video:
Unfortunately, when I tried, the mesh was not tranfered correctly to Archicad, as seen in the image below:
I've used Rhino 6 and Archicad 23. Does anyone knows how to solve this?
Thanks!
Breno
1 REPLY 1
Mikael01
You need to check how you are weaving your data. Could you share the GH script here ?
