My Rhino keep crashing whenever it tries to send to ArchiCAD 23. It isn't a complex script and the same script was working. Is there any way to fix this or does anyone else have any experience with the same issue?
I've attached an image of my script. As you can see it isn't very complex. It crashes with or without the button.
Any help would be great.
Thanks
EDIT: I've narrowed it down to if a zone has a hole cut for a column, it causes the error. Which is strange as it previously worked when I tried it. Is anyone able to help me get around this issue?
Thanks again
ArchiCAD 27
Windows 10
