jc4d
Set size limits in param-o
Hello, I'm trying to create a simple cube (to evaluate how flexible param-o is) with only two size options, 1m and 2m but I cannot find a way to do it, if any.
1 Solution
Rajesh Patil
Try this
Hope this is what you expecting.
I have attached one zip file which you can extract and use in Archicad.
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
Go to post
Rajesh Patil
Try this
Rajesh Patil
jc4d
Thank you for the suggestion it works as intended.
